When I am trying to play an AVI file my player (either WinMedia Player V9 or UltraPlayer V2.112) doesn't recognise the file type. Also when I am trying to convert it, it does the same. Should I be download/install DivX latest or something similar...Any help is appreciated. Thanks.
if you cant do anything with the file then your missing the proper codec to decompress it.
Download the nimo codec pac and install it, you may want to get the Xvid codec installed also. -
I don't recomment downloading the Nimo Codec Package. It contains some spyware and other bad stuff.Originally Posted by SLBOSS926
Use this guide as it tells you which codecs you NEED:
http://www.vcdhelp.com/forum/userguides/135217.php
Hope That Helps!!!
:P
converting, burning, and playing avi files
By unionman4077 in forum Video ConversionReplies: 1Last Post: 27th Feb 2008, 18:01 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
