Hi folks,
Just in case you don't know, it is now possible to make this irritating card ( or any other on with a Phillips SAA713x chip on it )work with most capture applications.
For details, check out the home page of VirtualDub, www.virtualdub.org
You'll need to fiddle the registry and may need to re-install the drivers as well but it does work.
I picked up one of these little monsters but could only make it work with VirtualVcr. Now it runs with almost anything at full PAL resolution of 704x576.
If you've had one on the bookshelf, it just might be time to get it down again.
Have fun,
Ian
