Every time I try to convernt in TMPGEnc, I get the error can not open whatever.wmv or the file is unsupported also tried stoikvideo converter and said can not open input file?
this plays fine on my computer though? how do I convert this to an avi?
In TMPGenc make sure that in the 'Option' -> 'Environmental Settings' -> "VFAPI Plugins', 'DirectShow Multimedia File Reader' is selected and has a priority of at least '1'.
neither worked...? the file plays perfectly on the computer.
renamed it in the command prompt tried to open it nothing, increased that value to 1 and 2, nothing. -
you can try Graphedit (check the tools section, and there's a tutorial somewhere in the "convert" tutorials)
however, I have tried it and got absolutely nothing out of it, and even some of the tutorials predict that it doesn't always work out.
had much better luck with the Stoik convertor, but it's not working for you, maybe Graphedit will work better for you then me.
good luck.
- housepig
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 09:25 -
How to Crop WMV Files ?
By devilcoelhodog in forum EditingReplies: 3Last Post: 23rd Mar 2010, 01:08 -
Lately, I can't view some wmv files
By videocheez in forum Software PlayingReplies: 6Last Post: 23rd Nov 2008, 18:54 -
how can i join VC-1(WMV-3)files
By sumeshkri in forum Video ConversionReplies: 3Last Post: 26th Oct 2008, 01:21 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
