CAn I take a wav from and convert to AC3 (5.1)? If yes, then is be sweet the program to use?
thanks
BeSweet is more for 5.1 to WAV, or more correctly 6 channel down to 2. Or downmixing 5.1 audio to a 2 channel AC3 compatable WAV for use in AVI/SVCD. To go form 2 channel to 6, you have to manually balance the audio. Yes you can do it with some non-free software, but it's now what you are thinking. If you already have the AC3 sound, keep it, it's typically 'good enough' and no amount of work will make a better 5.1 soundtrack.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I had just heard that you could tak a wav or mp3 file and make 5.1 sound. I have no AC3 streams, so i have to go from wav or mp3. can you point me to a program for this (simple one if possible)
thanks -
be sweet can do this, I do it all the time. Mostly converting mp2 -> ac3... but I do wav -> ac3 as well. Not sure about the 5.1 though.
-=| Felix |=- -
Softencode 5.1 is a great simple program for converting waves to 5.1. I use it all the time.
What do you use for the source of your 6th (subwoofer) channel? I like to put belly noises in for my tv caps to dvd conversions. I find most of my source wav files are really mono masquerading as stero.Originally Posted by MCD
Some of you aren't listening. How can you take 2 audio channels and make 6? You can't.
AC3 isn't 4 audio channels, it's 2 multiplexed channels. This means you don't get distinct left, right, center, and rear sounds.
Now if you want to take 2 audio channels....merge left+right for a simulated center, fake flip left front to left rear, fake flip right fron to right rear, and low-pass filter the bass to the subwolfer channel.......go for it. It's still stereo, specifically it will be simulated surround, just like most stereos can produce.
You can always add your own additional tracks. Good luck, this isn't a minor undertaking.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Ah Gazorgan you're no fun!
Take the origional 2 channels, put them to front left and right, add the belly grumbeling for good old ".1", throw in a plane fly-by on the 2 rear, and forget the center cause that's for voices anyway. Boy, just think of the possibilities if you worked with porn !?!
6 WAV files to one 5.1 AC3... need more help please..
By RogerTango in forum EditingReplies: 17Last Post: 13th Oct 2012, 09:00 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 03:29 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 15:44 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 05:03
