I downloaded the Sample VCD from this site (Flying around the Snow-covered Mountain). Upon inspection, all the moving scenes have what looks like two successive frames morphed into one. It's as if it was captured without de-interlacing and then just blended or smoothed. I then bought a vcd of a movie (XXX) on EBAY and noticed the same "double exposures" on the scenes with fast motion. Is this an error in the encoding, or should I expect this from all VCD's?
Perhaps I just don't understand the mechanics of what is happening here. Please Advise...
Thanks...![]()
K Sheldon
VCD's are at best about VHS quality and that's when there's little or no motion. High motion scenes look terrible no matter how good the encoder is.
Non-compliant VCD's using VBR will yield better motion scenes but with low resolution it will still not look as good as a DVD. -
Odd, maybe just bad encodes, or perhaps your hardware is playing up and not putting the frames in the right order, especially with the SVCD.. are you viewing on the PC or a TV?
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
Both TV via the DVD player for VCD, and I ripped them to MPEG1 and they looked the same.
Kevin
K Sheldon
Blurry video...
By Delora in forum Video ConversionReplies: 4Last Post: 17th Dec 2010, 12:23 -
blurry video
By drew68 in forum EditingReplies: 0Last Post: 6th Dec 2010, 13:12 -
Blurry Video
By homantam in forum Latest Video NewsReplies: 1Last Post: 24th Feb 2010, 08:34 -
Why are there spurious? frames in my interlaced PAL capture - sample clip
By BigMick in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 08:29 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26
