The way that it anchor links from the words to the definitions is with the # tag, the problem is that it doesn't seem to be supporting any spaces in the names. Thus every word that has a space in its name will not allow you to click on its name at the top and go to its definition.
Add %20 where the space should be.
example Main concept encoder -
Yeah kitty and I talked about that. Even with the %20 it didn't work for me.
problem when adding the [url=#%20]? or when browsing???
The probelm cane when I tried to click on any word up top in the list that had a space. It would not go to that corresponding definition.
It seems to work, but I won't be able to try it on the systems I had the problem with until Tuesday.
Could the definition for h264 be added to the glossary?
By yoda313 in forum FeedbackReplies: 2Last Post: 27th Jun 2010, 07:50 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
