I've heard it mentioned so many times on lots of posts, but I still haven't got a clue what this Avisynth is ?
Can anyone explain, or are there guides/explanations on here somewhere ?
Panther
All say Grrrrrrrrrr...................... -
You gotta try it out.
I've recently been capturing Scooby-Doo episodes and putting them on dvd. The most fun I had was using avisynth to create the motion menus. It was a snap.
Generally:
- Load a jpeg for the background (haunted house), and turn it in to video 1000 frames
- load 5 clips 1000 frames, from mpeg or avi, resize and position them
- load a jpeg "pictue frame" of bones, mask it and lay it over the clips. Everything but the bones are then transparent .
- Open it in virtual dub and fix the frame rate then encode with cce
All the work is done by Avisynth in not to many more lines than this post.
Check out this gui. It can really help you try different things and see the results right away:
http://www.neily.demon.co.uk/
New AVISynth UI
By tin2tin in forum Latest Video NewsReplies: 23Last Post: 19th Jan 2012, 01:53 -
avisynth
By sportflyer in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2010, 04:36 -
Using avisynth
By bsuska in forum Video ConversionReplies: 8Last Post: 16th Jul 2009, 08:32 -
AVIsynth help!
By helper in forum Newbie / General discussionsReplies: 11Last Post: 15th Oct 2008, 03:35 -
Avisynth 3.0
By nbi in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:50
