Never had a problem until I just yesterday read another member having the same problem.. tried re-booting 3x and nothing. I'm using CCE 2.64, i feed it the .d2v file, enter all data, hit encode and save as .ecl file.. just freezes.
Another tidbit, I just did a fresh re-install of Win2000.. Anyone?? Also, is there any benefit/s in using CCE 2.66 latest version?
Thx
I've heard of that problem, but I think I heard it was related to a crack, and if you are a registered user, try the update. If it works, it's certainly an advantage.
CCE 2.66 is much better version than 2.64 .. if you own it .. upgrade asap ..
Sony S580 region locking
By cheekiestgrin in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Oct 2011, 20:46 -
Help; Capture Locking Up with Canon Elura 90 DV
By bj4jc in forum Capturing and VCRReplies: 2Last Post: 22nd Nov 2010, 23:37 -
Slow & locking up
By BLSAMPLES in forum ComputerReplies: 7Last Post: 17th May 2010, 15:17 -
Why is DVD Decrypter locking up?
By dphirschler in forum DVD RippingReplies: 11Last Post: 14th Jan 2010, 22:34 -
Subrip2scc locking up?
By Lbrow in forum SubtitleReplies: 0Last Post: 12th Jul 2007, 15:08
