My Win2K system (Atlhon 1.2GHz) for video editing and X/S/VCD creation crashes so often lately, I suspect some kind of memory problem because I already try latest drivers (4 in 1 fir VIA chipset). Actual it was very stable since I first bought it.
Is there any diagnostic software for PC to check memory, CPU, etc.. out there I can download ?
thanks
There is one by Ontack called System Suite 3 it does what you are looking for plus a few more things.
http://www.ontrack.com
Norton System Works will do the job. You can download a demo at http://www.symantec.com
Go to http://www.tweakfiles.com and download a copy of RAM Idle, you'll find it in the memory section along with some shareware and freeware memory checkers/managers.
I use RAM Idle to reclaim memory before any video processing. It really helps in "not losing frames" recording with the ATI-AIW TV recorder.
B.T.W What Capture card are you using?
<font size=-1>[ This Message was edited by: Vidbox on 2001-09-04 01:04:47 ]</font> -
Thanks for all the answers, I will try them.
Here is my system config:
T-Bird 1.2 GHz + 256MB memory
DVD-ROM 12X
HP CD-RW 4X
30GB and 60GB UDMA-100 HDDs
TMPGEnc 12a and 12f for encoding
Nero software for CD burning
Firewire for DV capture
My system just behave very strangely last week, I restore a back up image of my system hard drive (this back up was done 2 months ago when the system ran realy well), it still does not solve the problem.
Problems occur while encoding with TMPGEnc (most of the time). Either it crashes the PC, re-boot it or as of this morning, it freezed a few minutes into SVCD encoding.
Sometimes, it finishes encoding. As soon as I click on My Computer (to check the MPEG file), the system re-boots !!!
It just sound like a hardware problem to me.
I finally have time to install RAMIdle in my system and ... the result is GREAT.
My encoding no longer crashes. The good thing is there is a status of how much free RAM the system has at any time in the task bar.
Thanks for all the suggestions.
ktnwin - PATIENCE
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 09:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
