when i encode to SVCD, all the sides are cut off. I have a rounded off TV so i could understand that, but when i took it to my friend's house with a flat screen, i could clearly see that a little video from the top and bottom were cutoff and some of the subtitles aren't readable. I am using tmpegenc Plus.
Thank you,
Dan
got the samsung c621
This is because of overscan, if you do a forum search on "overscan" you'll find more information than you ever wanted about it.
is there a way i can scale the resolution of the mpeg2 down so i can see the whole picture on the TV, with having minimal black borders?
thanks,
dangot the samsung c621 -
Overscan:
The area at the edges of a television tube that is covered to hide possible video distortion. Overscan typically covers about 4 or 5 percent of the picture.
Hope That Helps!!!
:P
Yes there is a way to fix this. When you encode the MPG you need to select "Center (Custom Size)" and then type in a size that you want the finished video to be. I find that 320x432 gets the entire picture on the screen with little or no border visible depending on your TV.
how to cut....
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2008, 03:28 -
n00b saving in Ulead for svcds and dvds myspace
By dsound in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2008, 13:40 -
2.5.3300 SVCDs getting recoded
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 15th Oct 2007, 22:44 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 17:02
