I ripped a movie with smart ripper. Then I converted it with DVDX. When I try to put the movie in movie factory it says that it is the wrong file type. It is mpeg format. I don't understand what is wrong.
Are you creating vcd,svcd or dvd?
What is the error msg?
What settings did you use in tmpgenc? -
In dvdX if making compliant mpeg's you should click the button to check standard so that the output is fully compliant for VCD/SVCDOriginally Posted by rizay
Sounds like you made a non standard mpeg
KingJohns Easy, Quick DVD ripping guide *****
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 04:31 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
MPEG Layer 2 video file, is it an editor friendly file type?
By ferran275 in forum Video ConversionReplies: 18Last Post: 17th Apr 2010, 00:41 -
what file type to use?
By Eric998765 in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2008, 11:55 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39
