Wondering how to check if a mpg file is Pal or NTSC?
Check the framrate.
25 fps is PAL
23,97 fps is NTSC film
29,97 fps is NTSC
It's all in the guides for WHAT IS a VCD or SVCD -
Ok, but i'm wondering what app easiest gives this info?
E.g. i have a file test.mpg. I need to know, is this PAL or NTSC? -
Or right-click and choose Properties in the older versions (or hey, even through explorer without using media player). In the second tab, if the height is 240 or 480, it's NTSC, if it's 288 or 576 it's PAL, if it's anything else come back and ask again!
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
