Hi,
I have a long recorded .AVI file of TV show episodes I recorded from my VCR to my computer using my Canopus ADVC-100. Is there anyway I can Encode the file to .MPG with TMPEG first and then split up the .MPG episode by episode eliminating the commercials? Or do I have to eliminate the commercials first with a .AVI editor and then save the individually (episode by episode) and then just batch encode with TMPEG?
Can anybody suggest any programs to edit out commercials from .AVI files and then highliting specific episodes and then saving them on your hard drive as individual episodes?
Any help would be GREATLY appreciated!
Thanks!!!!
-Joe :P
Either way - avi or mpeg
Edit out commecials in VirtualDub or Nandub for avi and use TMGEnc to edit out the commercials for mpeg (File>MPEG Tools>Merge&Cut)
There are a bunch of other programs that you can use also (see the extensive tool section on editing), but Nandub and TMPEnc are pretty simple to use. -
Can you write a DVD with just one .MPG file and having a program cut it into chapters? Or do I have to manually cut each episode from the main .MPG (or .AVI) file and do them seperately?
Thanks!
-Joe -
Originally Posted by jowel13
best program for separating one large MPG file to several sequential files
By nplovernmi in forum EditingReplies: 3Last Post: 20th Aug 2011, 17:09 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 12:47 -
Splitting avi file
By tryst1 in forum EditingReplies: 2Last Post: 15th Nov 2007, 03:33 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
