Hello, I have an ATI TV Wonder, USB..... and have recently formatted my Hard Drive, Prior to that I was using Power VCR with my TV wonder, after formatting Power VCR is giving shocking captures with dropped frames everywhere, and stuttery sound. I am running Windows XP Pro, and was before formatting as well......
Anyway, after reading a few things here, I decided to try Virtual Dub, to see if It would fix my problem, ( Plus I wanted to be able to capture in AVI).....
Virtual Dub captures the picture beautifully, but I have NO SOUND at all, Its not capturing the Sound........
I know the sound works in capture as Power VCR captures the sound, but Virtual Dub wont,
Can anyone help...
Many thanks in advance.
Terrie
double click on the volume control
goto properties and click on adjust for recording. Hit ok
Now select different recording sources. This should fix it. -
Hi, thankyou for your reply, if I click on the volume control there and click on recording, it gives me a series of boxes that I can check.... Im using Windows XP Pro... do I just select all of those boxes in the recording area?
thanks again
Terrie -
your going to hav to use trail and error. mine is set on CD. But before i had to click on one button, record/capture, listen for sound, click on another button, ect...ect... until i found my recording source
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 20:45 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 14:35
