I have Pinnacle DV 500DVD & Premier & Impression. DVD has the Jitters during pans, etc!! I've narrowed it down to the Upper vs lower frame first issue but am getting conflicting info from other Premier/ Pinnacle Users & Forums. I captured HI8 Analog Using Lower Frame First on ALL settings thru to final DVD. I captured to AVI, rendered & then sent to MP2 files to impression in which I did menus, etc to final DVD. I've got 80 hours of work in great professional looking Videos & have the terrible fealing that to fix this, I'm going to have to start OVER capturing with UPPER frame first - even though Pinnacle uses Lower in their export as Default!! I know that field dominance (or the field displayed first) can vary - depending on the equipment utilized to capture. So this apperas as if it could be an ongoing problem if I get media from different sources. So I was wondering if the "Select reverse Field Dominance" option in Premier 6.5 might Fix my problem. Any Suggestions?![]()
Best quality I got!! Very simple no jitters!!
Compile to raw AVI (skip video conversion etc)-> Bring directly to Ulead DVD workshop using raw AVI -> Create menus, music, etc in Ulead DVD Workshop --> Compile to DVD folder (Vide_TS, etc) --> Burn with Prassi Primo (don't use Nero)
End of story!!! BAM, best quality home videos!!! -
Make sure that when you encode do MPEG-2 that you have your field det to Bottom B, if you use Top A it will give you the jitters, also be sure that the encoded file is interlaced, this is necessary for DVD burning.
Jitter playback on DVD player
By Mylo in forum Video ConversionReplies: 4Last Post: 29th Oct 2009, 07:21 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 03:21 -
What DVD Recorder Corrects Tape Jitter?
By deuce8pro in forum RestorationReplies: 10Last Post: 21st Sep 2007, 23:52 -
'jitter' frustration on DVD
By hondo2160 in forum Authoring (DVD)Replies: 3Last Post: 21st Aug 2007, 21:16 -
Screen jitter when transfering from VHS to DVD
By Corey in forum DVD & Blu-ray RecordersReplies: 10Last Post: 31st May 2007, 18:43
