The format is Divx Mpeg 3. I'm using Virtual Dub 1.47 and I cut on a keyframe but the second half of the movie gets all distorted while the first half is fine.
I start the prog and leave most of the settings as it is.
I make sure video and audio is direct stream copy.
I go to the middle and find a keyframe and select it as my area to cut to the end.
I save as avi.
What else am I missing? What other programs do ppl recommend?
Suggest (if you haven't already):
-Check for bad frames.
-Try a different key frame as the cutting point. -
What is the audio format ? and what gets distorted...just the video or audio and video ?
44.1kHz stereo. Sorry I forgot to mention the distortion in the 'cut-off' movie more specifically. It's mostly just video distortion. Upon start up of the movie, I'll hear the audio but the video is all green. Then after a few seconds, the picture gradually comes in. The rest of the movie's video is noticeably distorted compared to the original. On some tries the audio would be out of sync but it seemed right most of the time.
The original does have a few bad frames so I could've just been cutting at the bad ones. I'll try it at cleaner keyframes and hope for the best.
1st and 2nd Pass with VDub/VDubMod when cutting out frames.
By Chakra in forum Newbie / General discussionsReplies: 20Last Post: 11th Mar 2011, 17:45 -
Resize Divx/Xvid For Portable With VDub: Artifacts/blur
By gordonliu in forum Video ConversionReplies: 6Last Post: 4th Apr 2009, 08:42 -
Cant seek my encoded divx avi's with HW players ... plz help
By samykoka in forum Video ConversionReplies: 2Last Post: 17th Mar 2009, 13:19 -
VDub/Divx - How to setup Aspect Ratio
By neomaine in forum Video ConversionReplies: 7Last Post: 6th Feb 2008, 16:05 -
Is there not something better than virtualdub for divx cutting?
By pondleaping in forum EditingReplies: 23Last Post: 5th Jun 2007, 11:45
