  1. I'm using TMPGEnc (for the first time, this is my first conversion) and i get to the part of the project wizard where i want to cut the movie in half so it can fit on a disc, but when i click the box "Source Range" the program always freezes on me. Anyone know whats wrong?
    Apr 2002
    The State of Frustration
    This is just a guess, but you may want to remove it, then reinstall it. You may have gotten a bad installation.
    Hello.
  3. Banned
    Jun 2001
    UK
    this should help
    KingJohns Guide TMPGEnc Plug-in
  4. Hey thanks for everyones help, but i figured it out yesterday and made my first VCD! I just used the avi file as the audio input instead of making a wav
