i've got two m2v & two ac3 files that i can import in to maestro just fine. what i need to do though is merge these files together, then import them in to maestro. but when i merge them through tmpgenc using the 'mpegtool' maestro says they're invalid. can someone tell me how to correctly merge these files so that maestro will like them?
thanks for any help provided.
you dont need to merge the files to import them into maestro ..
load each m2v file on the time line
right click on audio time line and select create sync audio track and you can figure it out from there
Muxing .m2v & .ac3 to .TS file
By randronoth in forum Video ConversionReplies: 3Last Post: 21st Jun 2011, 02:21 -
merging .264 with ac3 with mkvmerge goes out of sync
By jylau125 in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:55 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 11:54 -
Merging AVi's & including SRT's
By supersi in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2007, 09:40 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 08:56
