  1. Member kpoman's Avatar
    Jan 2003
    If one of my DVD's contains both DTS and Dolby Digital 5.1 and I keep both streams in my rip, then burn to DVDR, which audio stream will take precedence? In other words, when I play the DVDR, what will I hear...Dolby or DTS? Thanks.
    Live Long, Play Hard, Think BIG!
  2. Audio stream 1 (IIRC 0x80)
  3. Member kpoman's Avatar
    Jan 2003
    Can I strip the Dolby and just keep the DTS if it is not stream 1? Will DTS then be the only audio played? Thanks!
  4. Yes you can just strip the DTS, however you may have to change the pointer for it so it becomes Audio Stream 1 0x80. It has been awhile since I have done that..I dont remember exactly how...but
    doom9.org forums has it I am sure.
    goodluck
