I've got QTpro, but with some QT files that I want to load into tmpge require me to seperate the audio. the problem is that some of the files say "this movie doesnt allow saving". Does anyone know a way around this?
thanks-BSR
Total recorder - basically it will record a wav file (in real time) of the qt file.
thanks, will this work even with the "cant save files"? Also, is there a website with a demo or a download link?
thanks again
-BSR -
you can also remove the 'doesnt allow saving" see here :
http://www.vcdhelp.com/forum/viewtopic.php?t=124856&highlight=quicktime+bmw
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 04:50 -
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13
