Hi
I have a question. I have a standalone DVD player. It plays both region 1 and 2 (and it is also region free). I live in Europe. Is it possible to play a DVD region 1 (where it says US and Canada only) on my DVD player? My TV also only plays PAL. It's because I can't buy this DVD where I live. It's a DVD with Buffy The Vampire Slayer First season, here is a link : http://www.amazon.com/exec/obidos/ASIN/B00005221I/qid=1043864579/sr=2-2/ref=sr_2_2/103...252190-1744621
Thanks for any help
Sara
It is possible. Did you check if your player is liested here ? What you need to look for is if your DVD player does NTSC to PAL conversion, but if it can play Region 1 discs I assume that it should be able to play it.
When you see "US and Canada only" it means that disk is in NTSC and Region 1. At least that is my understanding.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Sara i'm using a Cyberhome DVD player and although when i bought it, it was a Region 2 only, i unputed a code uisng the remote to make multiregion.
It will now play DVD's from anywhere in the world.
All i suggest is that you a Scart lead when you do play the DVD's from America and Canada. -
BTW: This post should be in "Hardware" / "DVD Players" forum.
Region free Player from India - Onida BDX-1110 -hack for DVD & Blu Ray
By sahayarajs in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Dec 2010, 16:49 -
BluRay Region Coding Announced - Japan & US Same Region
By GullyFoyle in forum Latest Video NewsReplies: 57Last Post: 18th Dec 2008, 15:55 -
Issues with DVD-HD870/XAA ( region code & VCDs)
By chubbyswan in forum DVD & Blu-ray PlayersReplies: 5Last Post: 9th Jan 2008, 10:05 -
Region free for A&V D-66 Portable mini dvd player
By edmar_gabo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Nov 2007, 09:14
