I have the 3 dtv files in my vdub folder which enable the tweak.
If i try to capture with dtv- am able to adjust settings to clear up video on any tv channel
Obviously would like to compress video while capturing-use a MJPEG codec
So would like to use vdub.
Am not able to figure out settings to use with bad tv channels.
What i use clears up video to extent of reducing file size by 20 %- but need to use noise filter in TMPGEnc for further encoding which is v v slow ( more than an hour per minute of video on my system-PIII 800-5400 rpm 20 GB HD-256 MB Ram)
Would appreciate any suggestions
My TV system is PAL B- use PIxelview TV Pro card- get excellent captures on good channels-almost DVD quality
Thanx in anticipation
Results 1 to 1 of 1
DSL connection problem - tweak
By Jeremiah58 in forum ComputerReplies: 8Last Post: 14th Feb 2010, 19:16 -
How can I tweak Vista32 for best Performance?
By nyfsmith in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 14:58 -
?uestion about a particular win xp tweak
By mol3000 in forum ComputerReplies: 10Last Post: 22nd Oct 2007, 15:11 -
Avisynth-Tweak color-question
By SerbianBoss in forum EditingReplies: 4Last Post: 9th Sep 2007, 10:30 -
Tweak My Reauthoring Process...
By oohah in forum Authoring (DVD)Replies: 4Last Post: 3rd Jul 2007, 03:18
