Hi,
I need some advice on making a DVD.
What i want to do is have a 720x576 DVD clip play at the start of my disc and then is it possible to have like say 12 VCD clips available to play on the disc aswell.
I need this be with a menu at the start.
Now I think I would be able to do this in DVD workshop.
Is there a chance I would need to patch the headers etc like with SVCD's?? to get them to play on a DVD-R
Any help on this would be of great help.
Many thanks
Monsignor
VCD Video is compatible with DVD. You have to re-sample the audio to 48Khz though. So bearing that in mind, what you are proposing SHOULD work, though wether or not DVD WS or any other authoring app you have will actually produce a DVD from 2 different spec mpegs I can't say for sure as I have never tried it. If it imports both into the same project you should be ok.
Hope this helps
P.S, don't forget about the audio! -
thanks Bugster.
good point about the audio I had totally forgotten about having to re-sample to soundtrack to make it DVD standard.
Many thanks for your time and advice mate
Cheers
Monsignor
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 05:22 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 03:40 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 04:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 12:50 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 19:55
