  1. Hello everybody, this is what happens:
    I´m trying to encode an AVI to a two-cd mpg file. For this I always use the wizard and I always get good results, but the last two projects this happened.
    When split the file in two using the source range, the first cd output is perfect, but the second one the image is jerky.(using the wizard)
    If I create just one file, it is ok, no jerky image, but when I try to split in two for CD back up, only the second part is jerky.
    Doing it without the wizard it happend the same. I´m using the right PAL template, so I don´t what the problem is.
    Could anybody help me?
    Thanks in advance.
    Aug 2002
    Try scanning the avi using VDUB for bad frames.
