  1. I had an AMD/Asus setup utilizing a Promise RAID controller and striping with 2 dedicated DDR's for video work. I had terrible results with capturing avi at many different settings. I am building a new Intel based system that has available Highpoint RAID and was wondering if striping is worth it. Or is it best to stick with the standard ATA/IDE config.
    Do people find performance benefits with striping? tia!
    The DEAD are alive again!
  2. I started using a Promise RAID setup and it was a Godsend. My dropped frames fell to nothing. But I use a plain vanilla Intel 850 based motherboard and I've noticed I don't seem to have a lot of the problems like this. It does seem quite a lot of others are having the probelm you described and if you do a search there are better technical explainations than I can provide already posted.
  3. Yes, after reading thru many of the posts on this topic there is no general consensus. I guess the only thing to do is try both ways and see what works best on my setup. Thanks
  4. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    There was once a test of different raid solutions at Tom's Hardware. Don't know if it still exists. Their conclusion was that yuo gained very little performance over a good 7200 rpm ATA 100 drive. But they liked the Highpoint one and also just making an NTFS stripe set.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  5. Interesting. I'd say my gains were phenomanal, both on speed tests and in the real world. I don't remeber the exact figures, since I set it up quite a while ago, but it was close to double on the speed runs. Plus, I went from dropping close to a frame a second to typically less than a dozen in a 2 hour video capture. Of the frames I drop now, I'd say all of those are tied to a tape defect or some bright flash in the picture so due to capture issues not drive issues.
  6. Used a Promise FastTrack for my first video rig and it was worth it
    now use a modded ASUS MB W FastTrack RAID and still it is the best
    the VIA chipset thing is no problem(actually had more problems with the Intel 440BX)
    RAID is the way to go
