I was just wondering if there is anyway to get EazyVCD to use VStrip and DVD2AVI, but stop so that I can configure TMPGEnc for each individual VCD. I don't want to fumble around VStrip or DVD2AVI. Can I do this?
Thanks in advance for any info you guys/gals could give me.
yes there is,
Just select "Only Rip Vob's" under the field "Output Type".
You will end up with the Vob Title Set and a D2v file.
Eazy as that.
By the way, what settings did you want to play with in TMPGEnc, as I am looking at putting in "Advanced Options" in the future.
Rob FergusonDVD to VCD made eazy
http://www.eazyvcd.tk -
I just wanted to be able to customize bitrates and generally play with the different settings. I've had some strange results using EazyVCD. The only discs that seem to play flawlessly in my player(ApexAD-1200) are movies squeezed onto one disc. I'm not sure why. I was hoping that adjusting some of the different settings would correct this. Do you have any suggestions....I'm assuming you're involved somehow with the software dick_p_t. Thanks for helping out.
Export Functions under MPEG Streamclip
By kannixpert in forum Video ConversionReplies: 0Last Post: 10th Feb 2011, 12:40 -
Breakup a huge mkv file into smaller pieces
By mysts in forum Video ConversionReplies: 7Last Post: 3rd May 2009, 15:34 -
video breakup and glitch detection software
By Zone3 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2009, 22:22 -
AMD breakup; chip production now to be Arab-owned
By ahhaa in forum ComputerReplies: 8Last Post: 8th Oct 2008, 22:53 -
Audio Breakup
By Sooner02 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd May 2007, 12:47
