Ok I'm trying to convert an xvid with Ac3 sound to dvd and change the framerate from 23.976 to 25 I have done the movie no problem and run the ac3 file through ac3 machine but now the audio is like 8 minutes shorter than the video... I read in a guide for a vcd I think that I know have to stretch the audio is this correct and if it is what prog should I use and how should I go about it. If it is no the correct thing to do can anyone tell me how to get the audio the same length as the video please
If any program can stretch AC3, then it's probably Sonic Foundry Soft Encode. Another way would be to convert it to WAV, stretch it and re-encode it to AC3.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
Something wrong here, surely? When you alter the framerate of the avi from 23.976 fps to 25 fps it will shorten the playtime. Your audio should be shortened accordingly to 95.9% of its original length.Originally Posted by AdamP_uk
I came, I saw and I concurred with the others that the way to do this is by first converting to .wav. 8) -
found an excellent tool for compressing wave sound from 23.976fps to 25fps. 6minutes to compress 1hr30min wave file. Much faster than cooledit etc. See topic:
http://www.vcdhelp.com/forum/viewtopic.php?t=140078&highlight=you know it's the anti-Midas touch when all you touch goes to shit..............
Problem stretching AC3 audio with Adobe Audition 1.5
By Gwar in forum AudioReplies: 6Last Post: 21st Aug 2011, 08:15 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 11:50 -
Framerate Conversion
By rackball in forum Video ConversionReplies: 10Last Post: 11th Aug 2008, 05:04 -
Changing the framerate during conversion
By 2nickelstripper in forum Video ConversionReplies: 2Last Post: 7th Dec 2007, 08:46 -
Audio framerate conversion?
By pYShTr in forum AudioReplies: 2Last Post: 28th Jun 2007, 12:05
