Hi
I have searched the forum for the answer to the following problem, but did not find the answer I needed, so am hoping someone here may be able to help me.
I have downloaded a couple of avi files and when I play them back either through realone player or media player it plays only the sound and no picture.
When I load it into virtualdub, it comes up with an error saying that I need a vfw codec compatible with windows.
I am running windows xp with a 1.8 p4 processor, a lot of memory and a large hdd.
I have tried loading the avi straight into tmpgenc or nero to convert but they come up with an error saying the file is not supported.
I have downloaded a vfw codec and installed it, but still nothing. I have also tried decompressing the avi using avidecompress, but still only the sound is played.
I really hope you can help as I am now totally lost.
Thanks in advance
Scarlet
You are missing a suitable video codec. Find and download a program called gspot. load your avi into this and it will tell you what codec you need. You can then download and install the required codec.
Hope this helps.
PS, remember, Google is your friend!
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
