i can load this particular avi file into Vdub. when i try to extract the audio (wav), it starts but at the middle, a window popups and Vdub says error in audio compression. thus, all i produce is an incomplete wav file.
also, i can't seem to open this movie in WMP. i can only play it using DivX The Player 2.0. if i try to drag the slider from the start of the movie to any part (for example, in the middle), the audio will play back from the start. audio is way out of sync!
is there a way to re-encode this avi to be able fix the audio codec problem? or is there a tool that can fix such problem? if so, what tool should i use? basically, im trying to convert the said file to mpg1. thanks.
have you checked the file for bad frames?
http://www.vcdhelp.com/forum/viewtopic.php?t=135552
Extract Audio from RM File without Convert it
By Bruno AUgusto in forum AudioReplies: 7Last Post: 13th Nov 2011, 08:48 -
How to extract audio from mpg file?
By paul.1911 in forum AudioReplies: 4Last Post: 9th Nov 2010, 03:35 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 18:57 -
Extract the second soundtrack from avi file
By SB4 in forum AudioReplies: 4Last Post: 4th Mar 2010, 11:44 -
Extract part of an audio file into a new file without rencoding?
By therock003 in forum AudioReplies: 4Last Post: 19th Oct 2007, 16:32
