Hi there,
I was wondering how much space is required to capture in UNCOMPRESSED avi, full frame and full resolution.
Can anyone help ?
Thx.
It is easy to work out.
An uncompressed video (PAL):
16 bits per pixel
frame of 704x576 pixels
25 frames per second
Thus, per second of video =
16 x 704 x 576 x 25 = 162201600 bit/sec
~ 19.3 Mb/s
If you capture in 32 bit, double this figure.
If you caputre in 24 bit, multiple this figure by 1.5
Remember, you have to add the bitrate for audio as well. (approx 0.15 MB/s).
Regards.
Michael Tam
w: Morsels of Evidence -
What does the number of "bits per pixel" have to do with ? Does it improve quality when this number is raised ?
Thx again. -
1-bit per pixel = black or white
8-bits per pixel = 256 colour or 256 grey tones
16-bits per pixel = 65,536 colours ("High-colour"
24-bit per pixel ~ 16.7 milion colours
32-bit per pixel ~ 4.3 billion colours
The number of bits per pixel are involved with the colour depth.
Regards.
Michael Tam
Oh, I see.. Thx vitualis.
Last question :
What's the ideal configuration for the color depth ? -
If you are planning on encoding to MPEG, 16-bit is enough. Correctly me if I'm wrong, but I think MPEG-1 is in 16-bit colour.
Regards.
Michael Tam
I'm planning on encoding to MPEG1 or MPEG2 (VCD or SVCD) and later on to DVD (MPEG2)
Well, can someone tell me what the color depth for each video format is (DVD, VCD, SVCD, DivX), so I will know which color depth is adequate for each format when capturing ?
Thx in advance
What is uncompressed AVI?
By andrewjameshoward in forum Capturing and VCRReplies: 35Last Post: 2nd Nov 2012, 07:56 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 08:20 -
MKV to Uncompressed AVI
By TheLarch in forum Video ConversionReplies: 3Last Post: 15th Apr 2008, 08:11 -
MOV to Uncompressed AVI
By sdiddy in forum MacReplies: 11Last Post: 8th Mar 2008, 09:10 -
.rm to uncompressed avi on OSX?
By midnightraver42 in forum MacReplies: 15Last Post: 10th Nov 2007, 14:01
