  1. Hi all,
    I know my question seem silly,but a friend of mine argues that one can burn a dvd disc from a cdwriter NOT from a dvd writer. Any comments are most welcomed.
    Thanks.
  2. Tell your friend if you rub a mellon on your jumper, it will stick to the wall, just like a balloon
    You can COPY a DVD video onto a CD with loss of quality. Perhaps he's just a little confused
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    No, you can't burn a DVD-R/ DVD+R on a CD writer. But you can create a "movie DVD" on a CD-R with your CD writer, that your DVD player will (well, might...) recognize as a DVD, and try to play (which most players can't do with grace). See Mini-DVD!
    /Mats
  4. Member Conquest10's Avatar
    Chicago, IL
    your friend? or is it you don't want to sound stupid. like "i have a friend named ... Johnny... Table. and he has a problem."
    it seems like everyday someone asks the exact same question. will it kill you to search a little? a dvd is NOT the same as a cd. different "laser." it cannot be done.
    Mar 2002
    United States of America
    Yeah, DVD's use completely different lasers compared to CD's.
  6. Far too goddamn old now EddyH's Avatar
    Jan 2003
    Soul sucking suburbia! But a different part since I last logged on.
    Sounds like a friend of mine who took a lot of convincing that minidiscs wouldn't play in a CD drive if you just cracked the case open... or similar for a Zipdisk in a floppy... or that changing the operating system or "hard disk" (ie the system box) could somehow make a dead monitor work.
    (sigh)
    If it's not you in disguise, print up a fake mitnick-a-like court injunction banning them from computers for the next 5 years.
    -= She sez there's ants in the carpet, dirty little monsters! =-
    Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
    Mar 2002
    miniDVD:
    miniDVD is a DVD video written onto a CD-R(W) instead of a DVD disc. miniDVD is also sometimes called cDVD. A miniDVD only fits about 15 minutes of DVD quality video on a 650 MB CD-R(W). Not many DVD players will play miniDVD - see the DVD Players miniDVD list for compatible players.
    Hope That Helps!!! :P
  8. Some people are also confused about the terminology used, or just don't know any better.
    To burn a DVD as you suggest in the topoc of this discussion requires a DVD burner, quite obviously.
    Copying a DVD, on the other hand, can be done to several different formats for example; VCD, SVCD, and DivX, which can be burned onto a CD with a CD burner.
