Hi, could n e body please explain to me how i can get a 2hr 40 min svcd to fit on a dvd-r, have taken into tmpgenc and converted so that i can join files, which is on 3 discs, after i have joined files, bitrate set at 2350, the quality of the pic is poor, if i use a higher setting for the bitrate when i try to take it inot sonic mydvd, it tells me the file is too big, used best quality setting in tmpgenc but looks very blocky, is there a way i can reduce the size of the file after i have done all the conversion without losing n e of the quality ??
Many Thanx
Max
assuming these were originally encoded to svcd specs (in or around 2500kbps) then bumping the bitrate up will do nothing in pickingOriginally Posted by md_mushroom
up quality... once it's lost it's lost.
-d -
Sorry, the svcd i have is dvd quality, but i need to convert it to dvd, have taken it into dvd2avi, to seperate vid and audio, then take it back into tmpgenc , to enable me to join files without audio going out of synch, set bitrate to 2500, joined 3 files perfectly after conversions, then when i try to take it into mydvd to convert to dvd, it tells me the filesize is too big.
Many Thanx
Max -
Sonic MyDvd is your problem here. It automatically converts the audio to uncompressed PCM, increasing the size massivley. Try another authoring tool that supports mp2 audio, there are plenty to choose from these days.Originally Posted by md_mushroom
I have got the programme - Spruceup, can this b used to author dvd's like My DVD, if so would n e 1 know the settings i use to drag the converted svcd into spruceup, i have tried it once but it came up with error - unknown file format
many Thanx
Max
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
video file to big?
By just in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2008, 00:34 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40 -
ISO file to big for CD
By vagg in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 14:02 -
conversion file to big
By jimk16 in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2007, 05:05
