I've tried everything i can think of and i still cant get any sound with TMPGN. It makes the video but no sound. Im running winXP and windows media 8.0. Please help. If its a problem with my sound, wouldnt still burn ok? AAAAAH! Im at the end of my rope. PLease save me from madness!!!!
-thanks
-BSR
also, when i try and play in media player 9 (just updated) it says codec error. What codec? it doesnt say. PLays video fine. No sound also in power DVD. Can play old svcd files that are on CD, but not newly made ones. There shouldnt be a difference right?
-BSR -
I think you'll have to provide more details:
What are you encoding from, and what are you encoding to?
What settings in TMPGEnc?
/Mats -
i'm just taking mov files and converting to mpeg 2
I'm not changing any settings -
when you say mov files, do you mean ****.mov as in Apple/Mac Quick Time format? Have you, therefore, installed the QTreader plugin for TMPGEnc?
Have you tried 'GSpot' (look in the Tools section on the left hand side of this site) to see what codecs your files are trying to use & which (if any) are not installed on your system?
Mats is right - if we're going to help, you're going to have to give some more details.
cheers,
mcdruid. -
yeah im useing quicktime and i have installed the reader. It takes the file fine, it just wont put out the sound. When I play it in powerdvd, its reads that it has sound? Alos, I'm at work now and I've got winxp here as well and the sound doesnt work here either? AAAAH!
-BSR
Banks are so freaking greedy
By stiltman in forum Off topicReplies: 12Last Post: 17th Oct 2011, 07:58 -
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
