i had the movie that play about 4-5hours on one cd i known it was ASF file and play on pc only, i like to burn it to cd so i can play on dvd player, can any one help me. THANK YOU
Results 1 to 12 of 12
Click on the Convert link to the left then 'Ctrl-F' and search for ASF.
You really should find some guides before you come to the forms. But if you want to know.
Get VirtualDub 1.3c (only version that supports ASF)
Load the asf into VD
Choose Audio > Compression : No Compression
Choose Audio > Conversion : 44100
Choose File > Save Wave
Download TMPGEnc http://www.tmpgenc.com
Install TMPGEnc
Load Template : VCD NTSC. PAl if you live in a PAL Country
Load the video file (ASF)
Load the audio file (the wave you saved)
Now press convert -
Split after encoding. TMPGEnc > File > MPEG Tools > Merge and Cut
Or you could use "sorce range" in TMPGEnc settings. -
i can't open the file the message say i didn't have permission to open the file.
Do you have VirtualDub 1.3c?
What program is telling you that? VirtualDub, TMPGEnc?
Be more specific. -
start a screen capture program
insert cd play cd
capture video from screen to avi
convert
enjoy -
Why would you want to do a screen capture? there are much easier ways. The only time I would do a screen capture is if the file is otherwise very hard to convert. RM used to be a pain in the ass. But not so much anymore because of EO Video. That is the only format the I would ever do a screen capture for. And I don't have to do that anymore. A direct conversion is much better, and easier. Maybe you should also read some guides on how to convert asf.
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 13:11 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:56 -
ASF file conversion woes
By andy99 in forum Video ConversionReplies: 5Last Post: 8th Dec 2008, 17:41 -
help on .asf file conversion
By fabpozzi in forum Video ConversionReplies: 5Last Post: 23rd Jun 2008, 19:13 -
ASF file conversion
By sawm24 in forum Video ConversionReplies: 7Last Post: 11th Aug 2007, 08:47
