Is there a way to improve video quailty on a mpeg file that I downloaded? It is a little bit pixilated.
Thanx in advance
Results 1 to 10 of 10
Yes, get the original source and re-encode it to a better resolution/higher bitrate.
You could also use Noise Reduction to remove some of those pixels.
correct
"speed's just a question of money. How fast can you go?" - Mad Max, 1979 -
You can re-encode the video at a higher res, running tons of noise reduction, and blur.
It helps alot. With TV episodes ect..
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 09:11 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
video quality to movie quality
By pitta1990 in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2007, 00:31
the noise reduction and blur helped alot!
