I have some vcds. but the background noise really disturbs me. Can someone please help me?
I've tried to increase the bitrate(no luck)
covert to ac3 (no different)
need help (very badly)
thanks
what kind of noise is it ? is it a constant hum or whine ?
My DV camera creates a whine which can be heard on tape. I use Cool Edit to isolate the noise and remove it with excelent results.
Bartman 8) -
I think it's constant Hum.. but I will give cool edit a try...which one did you use? there are serveral versions...
and also, how to use?
thanks -
I use cool edit pro.
In a nutshell:
Open your audio and find a bit where there is no other noise except the hum (the closer you can get to a pure sample of this the better). Select it and then do a noise reduction, clicking "get profile from selection" and then click 'Cancel'. Select the entire waveform and go back to noise reduction. The profile you created will still be there. Select OK and it will remove the humm for you.
If you can't get a pure sample you will have to fiddle around a bit to get one. The program is fairly easy to use and the helpfile is good.
Bartman 8)
background noise in dvd (from .mov)
By nunsepofa in forum ffmpegX general discussionReplies: 6Last Post: 4th Mar 2012, 21:14 -
Dvd with background noise
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2010, 10:58 -
Background noise removal - Please help!
By maurof78 in forum AudioReplies: 2Last Post: 3rd Oct 2010, 10:24 -
Background Static Noise..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 01:28 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 22:27
