Hi,I have recently captured some movies off of DTV in 352x240.
Why? Cause it is the only resolution my card will capture in.
My question is What is the best way to encode this with Tmpgencn
and burn to DVD.Can I increase the Resolution or will it just look worse
The captured AVI's look very good.Also I tried a segment in 352x480
on my PC it looks streched ,will it display correctly on a TV.Thanks Jim
If you can, capture uncompressed and then encode to MPG2 for DVD.
If you can capture at 352x480, that will increase the resolution and after encoding will look better then 352x240 as a DVD.
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Firewire capture - Encode on the fly?
By BruceLEET in forum DVB / IPTVReplies: 1Last Post: 30th Aug 2009, 17:45 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
DV Capture to WMV encode. Looking for some advice.
By silmarallion in forum Newbie / General discussionsReplies: 10Last Post: 19th Aug 2008, 17:02 -
Please offer suggestions for 352x240 mpg...dvd is pixelated...
By AshleyQuick in forum Video ConversionReplies: 3Last Post: 29th Apr 2008, 00:13
