I've got winxp OS. Is there any reason why this would inhibit my DVD authoring?
thanks
-BSR
Not at all, I use WinXP Pro for dvd authoring and I'm quite sure many other folks here have the same type of setup. Have fun :P
WinXP is great for all video work - nothing inhibits video editing or burning and you have no 2GB/4GB barrier on your hard drives if formatted to NTFS.
Panasonic DMR-ES45VS, keep those discs a burnin' -
Please update your ASPI layer for WIN XP as windows has removed it.
http://www.adaptec.com/worldwide/support/driverdetail.html?sess=no&language=English+US...aspi_471a2.exe
ASPI stands for Advanced SCSI Programming Interface. Originally developed by Adaptec. It is a software layer that enables programs to communicate with SCSI (and ATAPI) devices.
Also SP1 is recommended by SONY for the 500A environment for burning to be patched properly -
if you don't have an ASPI layer, I'm told, the ripper has to use a more-error prone metod -some kind of method of RIPPING called WIN/i/o-
supposedly less good -
hehehe I found out after formatting and installing XP Pro, that I could've converted to NTFS without having to go through a complete reinstall. This was back in December before I got my Pioneer A05. Silly me, I learn something new everyday though
eSATA not hotpluggable with WinXP?
By PartingShot in forum ComputerReplies: 6Last Post: 13th Sep 2010, 20:59 -
WinXP Thumbnail Change
By Anakha in forum DVD RippingReplies: 1Last Post: 19th Feb 2010, 11:44 -
Need a Program to convert avi/mkv/ogm to dvd that is free for winxp
By animefanx in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2009, 04:22 -
Re-Installing OS WinXP Home
By GT Music in forum ComputerReplies: 2Last Post: 17th Jun 2009, 18:47 -
Two problems with WinXP re-install
By tweedledee in forum ComputerReplies: 9Last Post: 23rd Jun 2007, 21:38
