Hi,
My DVD can play VCDs(NOT SVCDs). My DVD supports 5.1ch surround.
Is there a way to rip a DVD and make it into a VCD with some surround or at least stereo support?
Thanks in advance !
P.S.
What forum does this thread belong in?
proctorGuest
Normally if you use DVD2AVI to convert the audio to WAV or extract the AC3 and use besweet to convert it will downmix Dolby 5.1 to Dolby Surround or Dolby Surround 2. If your stereo has a Prologic/Prologic II decoder you'll get some basic surround sound.
Of course, if your DVD has a Dolby Surround 2-channel audio track that would probably be a little better to use than a downmixed 5.1 track, since it's already been professionally done. Either way, though, Dolby Surround encodes the center and back channels in to 2-channel stereo, so it should work for your VCDs. -
proctorGuest
Well, let me know if I'm doing the right thing here.
I rip with DVD Decrypter.
Then I extract the avi and a .d2v file with DVD2AVI.
Then I use TMPGEnc to make 1 big VCD file.
Then I use vobsub to extract the subtitles.
Then I use TMPGEnc again to filter in the subs and recreate two best fitting .mpg (VCD) files for two700mb CDs.
Is this the right way to get the best surround compatibility?
Should I use some kind of option in DVD2AVI when I extract the .avi file?
Should I also choose some kind of option in TMPGEnc for the audio?
Thanks. -
That sounds wrong on a lot of levels. You don't actually need a real avi file, and you shouldn't be running the file through tmpgenc twice.
Rip the DVD, so you get a bunch of vob files.
Use DVD2AVI to create a .d2v and a .wav (select Audio->Dolby Digital->Decode)
Add subtitles, refer to this guide: https://www.videohelp.com/forum/userguides/87065.php
Load your VirtualDub or avisynth frameserving file in tmpgenc as the video source, and load the .wav file as the audio source. If you're not adding any subtitles you can open the .d2v file directly in tmpgenc.
stereo downmix: surround vs surround 2
By codemaster in forum AudioReplies: 7Last Post: 29th Aug 2012, 12:06 -
DTS encoding ( Stereo to surround ) ?
By 3thman in forum AudioReplies: 6Last Post: 6th Feb 2010, 07:06 -
"stereo" file (two channel signal) - Surround or Stereo?
By zee944 in forum AudioReplies: 0Last Post: 4th Sep 2009, 06:53 -
Upmix Stereo to AC3 5.1 Surround
By midders in forum DVB / IPTVReplies: 2Last Post: 10th Nov 2008, 22:12 -
2.0 stereo vs surround with 2 speakers
By ecc in forum AudioReplies: 8Last Post: 13th Jun 2007, 10:58
