I'm a total newbie to capturing, but I just got the ATI TV Wonder VE card and had some questions
I'd like to capture TV shows and burn them to DVD in the future (as I dont have a DVD burner at the moment)
There are a lot of different options available for capture quality. I was wondering what the best option would be to maintain the highest quality for when i burn them to DVD, but still a rather small size so I can store a large number of shows untill I am able to purchase the DVD burner.
I thought maybe it would be smart to capture them at the highest quality and then covert them to a smaller format, like Divx and then convert them back when i get the burner.
As I said, im kinda new at this so if I said somthing stupid, go easy
thanks
The TV Wonder VE was my first capturecard and it makes a decent 352x240,3000kbps MPEG-1 capture which is fine for computer viewing or to later make a low resolution DVD.You might want to capture using PowerVCR as it allows capturing at 720x480.When you do get a DVD writer definately get a full version of TMPGEnc and/or a quality authoring program.
http://www.gocyberlink.com/english/download/dl_file.jsp?dl_id=40
ATI all in wonder help
By bobo666 in forum Capturing and VCRReplies: 1Last Post: 16th Aug 2010, 17:53 -
ATI AVIVO
By therock003 in forum Capturing and VCRReplies: 18Last Post: 28th Jan 2009, 19:31 -
ATI 7500 All in One Wonder
By justmehere in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2008, 16:08 -
VirtualVCR and ATI TV Wonder
By moorthy in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2007, 19:46 -
Hauppauge and ATI in same PC
By chris1379 in forum Media Center PC / MediaCentersReplies: 2Last Post: 13th Jun 2007, 21:40
