Does anyone have a guide for creating a disc image in ifoedit?
I always get an ERROR cannot locate imglib.dll
You have to get ImgTool 0.89 and extract in and put all the files in the ifoedit folder.
Check www.doom9.net the download section. -
Thanks NY Player. I did this but now it says "Cannot locate video_ts folder cannot locate video_ts.ifo
Any suggestions? -
When I use ifoedit to make images i make sure the VIDEO_TS folder is the root dirctory of the drive for ex:
C:\VIDEO_TS
D:\VIDEO_TS -
I had the same problem with the video_ts.ifo and one other file I can't remember now. If you didn't rip them from the original DVD from which you are backing up then they need to be created, which can be done in IfoEdit. I forget the exact menu flow to create them but you can do under one of the menu options. This option also updates your *.ifo & *.bup files but you'll have to save them to another directory and then write over the old ones in the VIDEO_TS folder as well as copy the video_ts.ifo and second file into the folder.
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15
