I am having VDUB problems resulting in a ACCESS VIOLATION VDUB CRASH or a DISK ERROR CCE Crash..
Using a dual athlon software raid system with XP Prof..
All diagnostics seem ok...
Anyone ?
Tnx.
Oh...
When outputting to a single not striped drive...
Same problem..
Other drive ...
Strange huh ?
Greetz.
Mike. -
You didn't say which version of CCE you are using. CCE SP 2.50 have a crash problem with Athlon CPUs. You need to add a "resample audio" line in your Avisynth script to avoid it, assuming you are using Avisynth. Or you better upgrade to newest CCE SP.
CCE 2.5...overlooked that
What I am trying to do is convert large files with canopus dv convertor, (in Studio 8, for the sake of simplicity) filter them in Vdub (newest) and then encode them to MPEG II to put on DVD +R/+RW
Main problem is VDUB...using simple filters (static noise filters and so on) the plain or MMX versions..no difference...VDUB crashes with a access violation. Tried the Pinnacle DV codec and HUFFYUV for this...
When procesing small pieces...no problem (in the beginning) but somewhere along the way it always crashes...it takes a lot of time putting the pieces together again...
Am now installing newest AMD 760 IDE drivers and trying the canopus dv convertor on the AVI before processing thrue Vdub.
Perhaps it's some pinnacle glitch.
I'll let ya know the outcome.
problem with Srestore (or something) script in Vdub
By spiritgumm in forum Video ConversionReplies: 9Last Post: 21st Apr 2011, 19:32 -
VDub + TextSub + multipass problem
By Keeyu in forum SubtitleReplies: 3Last Post: 14th Jan 2011, 10:11 -
VDub Problem
By heygurl in forum SubtitleReplies: 8Last Post: 9th Dec 2010, 19:38 -
Vdub problem
By RR420 in forum Capturing and VCRReplies: 0Last Post: 8th Mar 2008, 14:43 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24
