Technologically, DVD are suppose to be the BEST..sometimes I have a DVD disc that playing just like an MPEG /(VCD) quality.![]()
I don't know much about DVDs, but I still don't see much difference in DVD's is better verus old VHS. (Maybe just the compact disc, Audio with THX, DigitalDobly, etc..). Anyways most of the time I got the movie is poorer than VHS, I don't know why but it does.
Even on my relatively ancient TV, there is a pretty big difference between DVD and VHS...
Perhaps the cables connecting your DVD player to your TV aren't good?
Regards.
Michael Tam
w: Morsels of Evidence -
Regards.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
uumm..how can that be? I use an RCA wire as it recommends. Is there quality difference in wires also?
Thanks. -
actually some wires r made better than others.
wires made of gold or gold shielded wires r better because the gold repeals electromagnetic interference.
also, you may have a dad dvd.
i remember reading a company wanted to release a whole series on like 2 dvds. they put like 12 episides on a dvd but to do this they had to drop the bitrate really low. -
Wires do make a diffrence in picture quality like s-video is better then A/V and component is better then s-video. I think that some DVDs have bad quality over others like my two Cheech and Chong DVDs look like VHS quality and my newer movies look far better then those two. It may be because of a low budget to produce these less bought movies that quality is sacrificed.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
