And what methods do you use to attain optimum results?
My specific use is capturing DV from my DV camcorder with a firewire connection and then transcoding and burning the .AVI capture file to DVD. 2 channel audio OK for me. Not looking for excess complication.
Thanks for any information.
I personally use Ulead Video Wave 6 to capture to AVI. Add my music/transition/titles - a whole lot easier to use than premier. Premier is more powerful but a bit complicated.
I keep it in AVI format and import to Ulead DVD Workshop without converting to MPEG2. I use my jpegs for menus and create buttons using the Video. Add music to the menus (without motion) or it will repeat the music every 10 secs. I compile to the DVD folders.
Then I burn with Prassi Primo instead of Nero (some bugs once in a while, also Prassi works better with cheap media).
If I'm ripping movies, I will use DVD Maestro instead.
program to find out what type of audio & video
By rtrimarchi in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2009, 14:24 -
Deinterlacing & Choppy Video Results
By GreenLED in forum Video ConversionReplies: 20Last Post: 30th Oct 2008, 09:17 -
Encoding yields audio out of sync
By chrisr34000 in forum Video ConversionReplies: 3Last Post: 2nd Jun 2008, 07:21 -
Troubling Results with my audio & video
By uncleB in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Oct 2007, 01:02 -
S-video hook up yields B & W picture
By dzachau in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2007, 20:55
