  1. Does anyone have a method of ripping, editing, and writing to DVD 4.7gb for a DVD9 that has multiple episodes of TV shows on it? The DVD9 in question has six episodes of a TV show and I can't figure out how to back it up while removing the extras (FBI intro, trailers, etc...). I am currently trying by using DVD Decrypter on IFO mode and ripping each PGC that represents the episodes seperately and demuxing using Decrypter. This gives me 6 file folders each with a demuxed file set. Three of the six should be able to fit on one DVDR. So I need to figure out how to combine 3 on one DVDR and 3 on another DVDR? Should I just remux each episode individually and then will burning them to the same DVDR? Will it let me see all 3 episodes? Menu?, chapter points?, how to access each episode one all 3 on DVDR?
  2. Originally Posted by proxima9
    Does anyone have a method of ripping, editing, and writing to DVD 4.7gb for a DVD9 that has multiple episodes of TV shows on it? Will it let me see all 3 episodes? Menu?, chapter points?, how to access each episode one all 3 on DVDR?
    I recently backed up all 5 DVD's for Band of Brothers. Each DVD has two PGC's. You can do the same thing for 2 or 6 PGC's per DVD. I used DVD2DVD-R. Here is what I did:
    1. Use DVD2DVD-R on each PGC, one at a time. Each PGC is between 55 - 115 minutes. I reduced the total file size by setting the MB RESERVED between 2000 -2100 for each PGC. In the SETTINGS area check FORCE ENCODE to be able to adjust the MB RESERVED value.
    2. I played the menu file for each movie (0.vob) and captured each menu as a .BMP file using POWERDVD.
    3. I saved the THEME music from the menu file. This was about 10 minutes long. Using CoolEdit2000 I reduced this down to 1 minute .WAV file. You can convert the .WAV to .AC3 using BeSweet.
    4. Using Maestro I IMPORT MEDIA ASSESTS for each PGC (.m2v & .mp2), .BMP for the menu and .WAV for theme.
    5. I created 2 MOVIES & a menu from the assests.
    6. I used CHAPTER XTRACTOR to get the chapter points for each PGC and added this to each MOVIE
    6. Compiled
    7. Burn DVD
    I must say the end results are EXCELLENT!
    If you have any questions on MAESTRO you will find your answer in these links:
    Spruce DVDMaestro
    http://digital-forums.com/dvd2dvdr/intro.htm
    http://www.doom9.org/mpg/maestro.htm
    http://www.doom9.org/mpg/maestro2.htm
    http://www.dvdwriters.co.uk/articles/DVDMaestroUnleashed.pdf
    http://www.doom9.org/index.html?/mpg/maestro.htm
  3. That's great except I can't get the chapters to import to maestro I get an error message: "I-Frame Insertion entry frame is not consistent with current tape frame rate! I-Frame import will be cancelled. (0xc102008b)"
    What's up with that?!
  4. check the prefs in maestro and make sure you have selected pal or ntsc depending on what the source is
  5. NTSC is set as default in Maestro?!
