I have a PII 450, 384mb pc100 ram, abit bh6 mobo (udma 33), 8x DVD.
My friend has the same setup except XP2000+, 256mb PC100, gigabyte mobo (ata100), 16x DVD.
When I rip a dvd using smartripper to a 40gb hard drive on my pc, I can get a max of 1.7x DVD read/write.
I used my h/d on my friends comp (but with the same organisation of 2 hd, 1 dvd and 1 cdrw) and he aceived 10x DVD read/write.
I didn't think mine comp was that slow, but can someone explain where the difference is. Is it purely because my comp is slower, or is there a bottleneck somewhere where I can upgrade ie faster processor, pci ata 100 adapter etc. and if so, what increases could I expect?
Cheers
Dave
Results 1 to 9 of 9
Multiple people have the same problem. It seems to be a W2K and cheap DVD problem. I've tried different ASPI drives and can get it to rip at 1X instaed
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
it rips at 2.1x in W2K....changing asapi drivers will revert it to 1x. Nero and Adaptec have the same result. It als rips at 2x in the native W2K/XP driver ( the non ASPI one ). Even in PIO mode it should rip faster.
4.60 drivers? Where might they be obtained at? I got 4.72 as currentTo Be, Or, Not To Be, That, Is The Gazorgan Plan -
I have not tested 4.72 so far but read a few posts that 4.7x brought a few problems to some users...
it's having to decrypt at the the same time it copies the files from the DVD.
Thats why you p2-450 is so much slower then your buddies XP2000.
-d -
Originally Posted by davedaraveishere
Your best bet is to pick up a new MB and processor... you can pick up an AMD XP2000 and MB for less then $160 bucks these days. It's cheaper then picking up a faster (1.4Ghz i think is the fastest) P3.. which will run you like $200 for the processor alone, if your motherboard supports it.
-d
How can I increase DVD/Blu ray write speed?
By gsingh13 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2011, 21:47 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
Ripbot264 possible speed increase?!?
By cjbrown80 in forum Video ConversionReplies: 3Last Post: 10th Feb 2009, 10:26 -
Speed increase?
By calbear94 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Jul 2007, 08:45 -
Will disabling peerguardian2 increase my internet surfing speed? Thanks.
By gary11364 in forum ComputerReplies: 3Last Post: 6th May 2007, 19:40
