Not a standard by itself, this term is used when a group of image files are placed on a VCD and displayed in a format like a slideshow. There are two ways of doing this with VCD 2.0 technology:
1) Import the pictures into a video editing program, adding optional music and transition effects as desired. The time between pictures is decided by the filmmaker, not the viewer. The result is output as a VCD or even SVCD motion video file and authored like any motion video to VCD or SVCD. The resolution is limited to VCD 352x240 NTSC, 352x288 PAL or SVCD 480x480 NTSC, 480x576 PAL which may appear grainy or low resolution compaired to the original pictures.
2) Author a photo VCD 2.0 disc encoding each picture as a still MPEG at 704x480 NTSC, 704x576 PAL. This allows better resolution but (probably) lacks transition effects. The resulting collection of still MPEG images can be authored with difficulty in VCDimager/VCDeasy or you can use a program that automates the whole process from images to disc like Ulead DVD Pictureshow 2 (which also does VCD well). VCDhelp PhotoVCD Guides
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 1 of 1
