I have a VOB that is 5.2 GB and I want to encode it to VCD using ffmpegX and the QT decode option (for sync). Am I going to have trouble since QT has some kind of 4 GB limit?
Should I re-rip as tracks? I haven't done this yet so all help and advice is appreciated.
Thanks!
Thanks, Major,
So I guess QT does have some kind of 4 GB limit/bug. I wonder if that is true of the new QT 6.1 (I haven't installed that yet.)
P.S. There's been a lot of talk about 42. Just like to say thanks to you for all the work/updates you make to ffmpegX. It's a great app!
When I've tried two VOBs, I find that Quicktime deals with the first one just fine, but won't play the second. The error has to do with an incorrect file duration.
To get around the Quicktime 2GB limitation, I use OSEx to rip elementary streams (rather than VOBs) in chunks smaller than 2GB.
This lets me convert the audio stream too if necessary...Quicktime also can't deal with AC3 audio streams so they need to be converted to MP2.
Then, I use FFMpegX to Mux the elementary streams.
Now, if I could just resolve my SVCD sync issue...
FFMpegX - NOT seeing VOB's imbedded subtitles...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 14th Jan 2012, 10:10 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to mpeg2 convertor - not ffmpegx
By faxfan2002 in forum MacReplies: 8Last Post: 30th Jan 2008, 04:36 -
single .vob in ffmpegX to h.264 (mencoder) .mp4 a/v sync issues
By jabroni5 in forum ffmpegX general discussionReplies: 15Last Post: 7th Jun 2007, 17:48
