    Jan 2003
    Far Side Of The Galaxy...
    I've just tested a couple of films I've just backed up using DVDDecrypter, DVD2ONE and burnt using RecordNow.
    The films play fine until the last chapter, then the player just freezes.
    I have also tried burning the disc under Nero but with the same results.
    If I check out the copies on my PC under WinDVD all the movie is there. Anyone have any ideas on this one?
  2. I saw a discussion claiming that the sticky on labels where causing a similar error. If your using a label on your DVD, try it without.
    I personally don't use Nero, because I've receive the same type of problems. Try Prassi Primo! I've had better success!!
