  1. I've been using TMPGEnc 2.58 for quite a while without problems, obviously I've done something it doesn't like, but I can't find out what
    When I try and open it, it says something about causing an error with KERNEL32.DLL
    Anyone any ideas ? I re-installed Windows but it's still the same
    Panther
    All say Grrrrrrrrrr......................
    Aug 2002
    Delete the TMPGEnc.ini then try to open it? Does it work?
  3. Tried deleting the tmpgenc.ini but I still keep getting this error
    "Read error occurred at address BFF6A285 of module 'KERNEL32.DLL' with 0078FFB0"
    Panther
  4. Banned
    Dec 2002
    Somewhere I belong
    Try download the latest TMGEnc v2.510 and see if that solves your problem.
    You can get it from here:http://www.tmpgenc.net/e_main.html
  5. I came here to post the same problem about that read error, i follow advice i remove the tmpgenc and i reinstalled it and now it works.
  6. I am having the same problem. I unintstalled the program and rebooted. I then reinstalled and then upgraded to the newest version. I get about 50% though an encoding session and then the same error happens again.
